Black and White only?? | SatelliteGuys.US
jct9841
My Direct TV Tivo woke up this morning and is only displaying a monochrome signal. I've unplugged the box and powered up but still the same. Any ideas?
Thanks in advance,
John
Do you have it connected via S-video cable per chance? Sometimes I've seen this happen & it turns out the S-video connection has worked itself slighty loose enough to cause this same problem - make sure the connectors are plugged in tightly at both ends.
Antenna Reception Question
Directv and RG-59
