'Blackbird' box poses serious theft threat (D* and ExpressVu) | SatelliteGuys.US
silversurfer
1,147
Las Vegas, Nevada
EXCLUSIVE: 'Blackbird' box poses serious theft threat (D* and ExpressVu)
TORONTO - A new, card-free, theft-enabling satellite set top box which allows users free access to all Dish Network and Bell ExpressVu programming has hit the black market within the past 10 weeks or so - and this one is apparently unaffected by satellite company electronic counter measures (ECMs).
The box, available for sale on ebay and underground web retailers, is called Blackbird. The sites are billing the box as a legal, free-to-air receiver that just happens to allow access to all Dish Network programming. And, since ExpressVu's technology is identical, the box lets users steal from the Canadian DTH company as well.
Blackbird has caused such a scare in the States that when speaking to delegates at a Cablelabs conference last week, Comcast president Brian Roberts mentioned the box by name and urged Dish Network to take immediate, drastic action, according to those in attendance.
The box comes with no conditional access card and, say those who have seen it, can not be disabled by satellite company ECMs. It does not work with DirecTV or Star Choice.
"No more JTAGs, AVRs, Atmegas, ROM X Cards, ISO Programmers, and TSOP locks," says one web site, telling thieves they no longer have to worry about buying hacked cards, readers, loaders or anything else.
The Blackbird comes with a four-way connector, meaning that up to four dishes could be tied into the box. With seven Dish Network and ExpressVu satellites to choose from, depending on which of the birds the dishes are pointed at, such a thief could get in the neighborhood of 1,200 channels on one television through this box.
"You can connect up to 4 different LNBs to a 4-way switch (included) and one output to the receiver. Blackbird will understand each individual LNB signal, and download all the channels for that satellite. For instance, if one LNB were pointing as Dish Network, you would set up LNB 1 to download all 300 DishNet stations (PPV, sports, everything). This would populate channels 1-300 on the system," says one web site.
"If LNB 2 were pointing at another satellite company, you would then be able to set up LNB 2 to download channels 301-600. This can continue for up to 4 different satellite signals. Potentially, with enough dishes, you could flip from channels 1-1200, without missing any stations!! Although you cannot get DirecTV, you can use your existing DirecTV dish on your house, and the LNB, as long as you properly re-point the dish to another satellite, such as Dish Network."
The site, of course, also claims that all of this is, ahem, perfectly legal.
It's selling in the US$370 range.
Bell ExpressVu president Tim McGee told www.cablecastermagazine.com on Friday that his company became aware of Blackbird in December and is working on how it can combat it.
He downplayed its potential effect on the company. "It's just another pirated device that can be used to steal," he said. "We're well ahead of the curve in terms of our knowledge of it. It's a niche product"
McGee didn't say for sure whether or not the company's ECMs work to disable the box but several technical contacts in the cable industry with knowledge of Blackbird or who have seen it work, say current ECMs, which target hacked plastic cards inside set top receivers do not affect Blackbird.
"The best way at this point to fight it is to choke off any avenue of distribution and sale of this," added McGee. "That's the main thrust at this stage."
"It's not affected by ECMs," confirmed one cable executive who has seen the Blackbird work.
Industry Canada and Telesat recently conducted a test of the box in Ottawa and found that it appears pretty bullet-proof and is a serious threat to satellite signal security. Blackbird is a name which is beginning to reverberate throughout the TV distribution industry which is understandably spooked by the product.
It is another reason behind the redoubling of efforts to get Bill C-2 passed, which will dramatically toughen measures against satellite signal thieves.
For the entire article click here
I have read where this box may actually be a hoax and also read where it may be a way for the satellite companies to catch people stealing programming.
If that is not the case then how can they do this without a smart card? What would happen if Dish would shut down the stream for the blue cards once the card swap is done, or are not all the smart cards going to be swapped for Dish, just select receivers? Does ExpressVu plan on doing a card swap and using the same cards (chips) that Dish uses in their new cards?
stargazer,
The receiver would work using DVB card technology. It is all software driven. Rumour has it it works with Nagra II as well (yellow cards) with minimal freezing once every 30 minutes or so.
This is all speculation and there have been reports of people not getting their orders and their names being taken by ExpressVu in Canada.
Kryspy
If this does exist then seeing how it freezes every 30 minutes couldn't they speed up the data stream to get it to freeze up even more caused by the software/hardware/processor cannot handle it (I heard that DirecTv sped up the stream to get those using computers with cardless receivers to freeze up)?
Would this mean that they could write more software to allow it to work with new cards or to counteract what Dish does to them to allow them to work again? It sounds like it could be a new way someone has figured out how to do it with software instead of cards.
Since it is not a Dish Network or ExpressVu receiver would they even be able to hit it?
Apparently the Blackbird crew have officially abandoned the project now. Other like receivers are around though. Look for the Fortec receiver. I sense these little gems will all fall by the wayside. My opinion, they are the new scam.
Kryspy
