Blind Scan - SR below 2.000 | SatelliteGuys.US
ng54
72
Is there a blind scan receiver good at finding TPs below an SR of 2.000. Or is there any
tricks that can be used.
I usually have problems with receivers missing stuff below 4000-4500, but 2 that I personally used that did well were the Fortec Merc II and Traxis 3500.
Coolsat 5000 has been known to grab below that. I know my Pansat 1500 and 9200 can grab the stuff that is just below (1945, 1970) but never can grab the transponder for KFTL on AMC6 (s/r 1666) on a blind scan
I think the slower you (set the) scan, the better your chance will be? The faster scans will miss it, while the slower scans tend to do a more detailed search? So, get a receiver with slow scanning search engine.... I think?
One of my favorite peeves==Traxis 3500 I have has found channels with SR of 1505, that's the lowest I've seen yet. Seems like the best receivers for low-SR scanning are the ones that are a little older, or have the 'detailed' blind-scan feature. I have a Coship 3188C that also is older, simpler but has very good sensitivity, also will do a "under 2000 SR" scan. Seems the Merc II or the Traxis 3500 are two of the best for finding the low-symbol rate channels.
Good Input. I have the Visionsat and Pansat 2800, both have problems in this area. I wonder if the
Fortec NA with the variable scan frequency will catch the lower SR's.
I just tried the KTFL channel on AMC 6 that Iceberg mentioned and the Coolsat 5000 missed it on a regular blind scan but when I set it on detailed it picked it up.
mine didn't. I ran it through details from 11800 to 11900 and since its at 11890 it should see it...nope :(
Most stable DVB PCI or USB card??
Where to post a feed?
