Blind Scan | SatelliteGuys.US
Blind Scan
GaryPen
Rich or poor, it's good to have money.
Everything I've read so far leads me to believe there is no blind-scan-capable PC card FTA tuner. Is this correct? There are DiSEqC 1.2 & USALS capable models. So, how can they leave out this final, important feature? Is it something that can be added via software at some point? There seem to be a number of good HTPC apps with excellent FTA support. I just don't get it!
FYI - The product page for the Twinhan 1022 specifically states:
"Transponder, region, and Frequency range Auto Scan"
Doesn't that mean anything?
http://www.twinhan.com/product_satellite_1.asp
auto scan just scans the existing transponders (frequency, polarity, symbol rate) that are stored. It doesn't find anything new
Only known PC-based DVB card with Blindscan is Skystar 2.3. Its no longer made so you will have to find one used.
I believe that there is one driver ver for REv 2.6D that allows BS, but the ver as a lot of bugs from what I hear.
Walgreens music / Store music
Hispasat @30W Ontario, Canada
