Blue-Ray Training Day review. | SatelliteGuys.US
http://bluray.highdefdigest.com/trainingday.html
The Video: Sizing Up the Picture
'Training Day' on Blu-ray has a lot to live up to. Had this title been released on the format before it hit HD DVD, it likely would not have come under nearly as much scrutiny. Videophiles have been waiting with baited breath to see not only if 'Training Day' looks great on Blu-ray, but if it tops or at least equals its rival. Surprisingly, the differences between the two versions is substantial in more ways than one -- and unfortunately for the Blu-ray camp, it doesn't go Blu-ray's way.
But first, a note on this comparison. I hooked up both my Toshiba HD-XA1 HD DVD player and Samsung BD-P1000 Blu-ray player to my HP Pavilion reference HDTV via its two HDMI inputs. Note, however, that the first-generation Toshiba HD DVD decks are not capable of outputting native 1080p signals (unlike the Samsung), so it was up to the HP's internal processing to upconvert the Toshiba's 1080i signal to 1080p. Also, given the Samsung's much-publicized problems with its HDMI output (due to a reported faulty noise reduction chip that results in a degraded signal via the deck's HDMI out -- Samsung is planning to correct the problem on future shipments as well as issue a firmware upgrade sometime this Fall), I also compared both the Toshiba and the Samsung via component out to ensure the most fair comparison possible between the two discs.
So, how do Blu-ray and HD DVD stack up? First, there was one noticeable difference between the two transfers I wasn't expecting. Both the Blu-ray and HD DVD are labeled on the back of their respective packages as being presented in 2.40:1, but that's not the actuality. The Blu-ray suffers from a narrower aspect ratio, with some noticeable cropping on the sides of the picture. Though the total screen area of the bottom letterbox bar is the same on both discs, the total screen area on the top letterbox bar is visibly smaller on the Blu-ray. A physical measurement off of my 65" monitor showed the top letterbox bar is reduced by a good one and a quarter inches on the Blu-ray. Meaning that the picture has either been reframed for the Blu-ray during the telecine process, or the Samsung is outputting a signal that slightly blows up the image. I estimate that about three to four percent of the area on the sides of the picture is lost on Blu-ray. Note that I also switched the outputs on both players into my HDTV to make sure it wasn't a problem with one of my set's HDMI or component inputs, but to no avail -- the Blu-ray was still cropped. Unfortunately, with no other Blu-ray players available with which to do a comparison, there is no way of yet telling if the altered aspect ratio on the Blu-ray is inherent to the encoded material itself, or a fault of the Samsung player's internal circuitry.
Next, to assess picture quality, I did comparisons of three complete scenes on both discs, one after the other, simply by switching between my set's two inputs. I also compared a dozen individual still images, by pausing each deck on identical still frames and switching back and forth. The aspect ratio problem aside, the picture quality differences between the two transfers is often quite apparent. For example, during the very first shot of the film -- a zoom in on a red-hot, rising sun -- there was some polarization was visible on the Blu-ray, with the banding of colors obvious as the picture faded in. Looking closely at the HD DVD I could also spot some polarization, but it was not nearly as severe. These type of compression artifacts continued throughout both transfers, and I noticed about three or four shots on the Blu-ray with more polarization on backgrounds or during fades/dissolves, which were either not there on the HD DVD, or greatly lessened. So score one for HD DVD's VC1 compression codec over the MPEG2/AVC scheme used for Blu-ray -- at least until that format's larger-capacity BD-50 dual layer discs become commercially viable.
Another difference between 'Training Day' on the two formats is that the Blu-ray transfer looks darker. Right from the opening scene when Ethan Hawke wakes up in his bed, the HD DVD exhibits an obvious (if far from extreme) brighter look. However, black levels looked comparable -- the HD DVD did not seem washed out versus the Blu-ray. And while the Blu-ray image still looks detailed, shadow delineation does appear a bit less impressive in the darkest scenes. Fall-off to black is a bit sharper on the Blu-ray, which is to be expected given its darker cast. Conversely, colors can appear slightly more vivid on the Blu-ray at first glance, though the actual saturation of colors appears equal on both. It is not that the HD DVD looks washed out, but the darker appearance of the Blu-ray transfer can make hues seem a bit more deep by comparison.
In all other areas, the two transfers are comparable. The sense of depth and detail of both formats can be terrific. While the brighter HD DVD is more consistent, especially on the darker scenes, the Blu-ray is no slouch. Indeed, anyone sitting down with either disc would, during a casual viewing, be quite impressed by either. But a head-to-head comparison is all about the small things, and given the aspect ratio issue with the Blu-ray disc, plus the compression artifacts and slightly darker cast, I have to give this first face off to HD DVD.
BluRay version of "Rumor has it" loses to HD DVD as well.
http://bluray.highdefdigest.com/rumorhasit.html
Well, I was rather surprised with this one. No, the differences between this Blu-ray transfer and its HD DVD rival (you can read my review of the HD DVD edition here) are not night and day -- nor are they likely discernible to anyone but dedicated technophiles -- but they are more pronounced that I expected. As I noted in my earlier Blu-ray reviews of 'Training Day' and 'Kiss Kiss Bang Bang,' the biggest differences I noticed between the Blu-ray and HD DVD versions are brightness and contrast levels, compression artifacts and a slight cropping on the sides of the image. Unfortunately, all three issues also plague 'Rumor Has It...', and in some instances the inconsistencies are the most notable of any of Warner's three launch titles.
The cropping issue evident on the other two titles also persists with 'Rumor Has It...' Though it's a bit harder to detect with this one -- given that the film is presented in 1.78:1 and thus there are no letterbox bars to help gauge aspect ratio -- comparisons of identical still frames between the Blu-ray and HD DVD did reveal the same level of cropping. I estimate that about three to four percent of the area on the sides of the picture is lost on these Blu-ray releases, which is considerable. However, given that this alternation in aspect ratio is so consistent between all three titles, it is very likely a problem with the Samsung player and not the original encoded material on the discs. Unfortunately, with no other Blu-ray player available with which to do a comparison, there is no way of yet telling where the real fault lays. (Note that I also switched the outputs on both player sto make sure it wasn't a problem with one of my monitor's HDMI or component inputs, but the Blu-ray remained cropped either way.)
Aspect ratio issues aside, let it be said that 'Rumor Has It...' is a very good-looking film on either Blu-ray or HD DVD. Detail is terrific throughout, with fine textures clearly visible and deep, rich blacks. Colors are also vibrant and well-saturated, if sometimes so processed that all of the actor's faces appear to have been CGI'd more than Joan Rivers'. Both transfers also look quite three-dimensional, with a level of depth to the image that screams "high def."
However, the Blu-ray edition once again appears not only darker throughout the entire transfer, and contrast also suffers more acutely than on either 'Training Day' or 'Kiss Kiss Bang Bang.' For example, during the scene where Jennifer Aniston first comes home for her sister's wedding, there is a shot of her standing in front of an open front doorway. Flipping back and forth between the Blu-ray and the HD DVD versions, the Blu-ray image just didn't have quite the same pop. Whites were a bit brighter on the HD DVD, which made the fine blonde hairs on Aniston's arms clearly visible, while on the Blu-ray they blurred together in more of a brown mass. And later on during a scene with Aniston and Kevin Costner having a conversation while on a dance floor, some minor background details such as tableware and subtle light shadings were lost due to the darker cast of the Blu-ray. Compression artifacts, too, are also more distracting. I detected a few patches of what looked like noise or blockiness on such objects as flat, color walls and fabric patterns on the Blu-ray -- the HD DVD just looked more consistently cleaner and clearer. Again, none of these drawbacks are monumental, but the discerning eyes of this early adopter left me rather disappointed with the Blu-ray.
