I have a friend who bought a pair of Nakamichi headphones at around $70 or so and he is having a problem.I think I bought mine from NewEgg.
http://www.newegg.com/Product/Product.aspx?Item=9SIA1TX0K17060
They work well, The wife goes to bed long before I do. Allows me to listen at a higher volume.
I have a few friends that bought from dish, but not sure if it is only a DSHS from techs or if they work from agents also. They all got theirs from the techs and love them.
Negative. Not in the US. Draw your own conclusions...That sucks. New hire?
It seems that buy and try is the only foolproof way. Some quote that they will auto reconnect in the product description and they should work properly it would seem.How can you determine if a pair of headphones will auto recoonnect, short of buying a pair and trying?
I have a slew of Bluetooth headphones, none of which will auto recoonnect
Is there a list?
Is it the Bluetooth version or the audio profile?
I thought about getting a second ADAPT but wondered about pairing. Did you run into any conflicts with two of the adapters?Me too on the Adapt headphone adapters, I have 2 & they work great with everything I've tried.
Limited time offer
