AntAltMike said:That's not one of the ones I described, though I have seen it before.
I'm not sure that the Ku polarizer probe can be flipped remotely. Before you buy one of those, you'd better have Skyvision either confirm that the Ku signals are received by a linear probe that can be turned mechanically by the existing polarizer or that they have a linear Ku LNB that fits into that attachment that either employs 13/18V switching or "stacks" the two polarities. The LNB pictured looks like the circular one that they sell for mounting in the middle of prime-focus dishes.
FWIW, I bought one of Skyvision's DBS LNBs that was stripped of its feedhorn for prime focus use, and it seemed very noisy to me, and I know of another person who bought a couple and tried them in Venezuela and he didn't have good luck with them either.
The unit you pictured costs $100. The Corotor-II costs $120 from the same supplier and can often be had on eBay and elsewhere for less. You'd be much happier with the Corotor-II.
Limited time offer
