Brazilian Channel on Hispasat 1D | SatelliteGuys.US
emirelias
8
11929 Vtp 80 Rede TV! Sul DVB 2963-3/433 36 PAmericas T Zahnd050526
The above line is a copy and paste from Lyngsat. It's about a Brazilian channel on Hispasat 1D (30 w).I would like to know if is possible to get that channel in Toronto (43n,79w). What kind equipment do I need?
yes it is available
you would need a basic FTA (free to air) system
-30" (76cm) or larger dish
-KU band LNB
-satellite receiver (any FTA receiver will work)
I got 2 kinds of lnb.One is the dish stuff with a 33" dish thats good for dishnet .( I use for 61.5 ) and one Lnb that I don't use that's writen In it: 900 to 2450 mhz
9750 to 10600.
Question 1- is that dish good ?(someone told me that one antenna thats good for dishnet is not good for hispasat).
question 2 - wich Lnb the one for dishnet or the Fta ?
thanks in advance
I use a 36" dish for this channel/satellite you should be good with a 33" dish (BIGGER is Better).
Dishnetwork LNB will not work for this channel, they are circular polarized and this channel will need a linear LNBF.
For example a Standard KU LNBF
RF : 11.7~12.2 GHz
IF : 950-1450 MHz
Using a L.O. of 10750
Watching this channel right now (showinf some wild stuff!) ! Signal Quality here in MN = 75%
"Lnb that I don't use that's writen In it: 900 to 2450 mhz
9750 to 10600."
This LNBF sounds like a Universal LNBF, with a L.O. of 9750-10600 Should and work.
Got it .Working just fine .I'm in Toronto I tilt +2 lines on the lnb holder and worked just fine.
Pansat 2700a - Timer....
T-5 aiming
