Bringing old 80 cm dish back to life? | SatelliteGuys.US
delta_charlie
716
153
Hi all, I have an old 80 cm Ku dish up at roof level and I'm thinking of bringing it back to life. It has clear sight from about 15W to 90W with a tree that might be in the way from 90W to maybe 115W then clear again to near the west horizon.
It's not real easy to access and I would like to try and lock it down for news feeds or maybe some HD channels.
Any tips on active satellites would be very helpful.
Thanks, Dale
Reactions: FTA4PA
Thanks, Dale
There are news feeds on 87W. Used to be news on 91W but they went to internet distribution. :( Don't know if you can squeeze it out but Reuters Live Service is on 113W. :)
Thanks for the reply, I was thinking of trying 91W but it looks it will be better to try another sat. I need to get up on the roof and try and sight the dish - may be able to get near full arc with just a little trimming. From the ground it looks worse but offset dishes point a lot higher then they look.
Reactions: FTA4PA
Satellite Accessories: Princess Auto
GT Media V8
