I must have missed the part that says the new chip is a pin-for-pin replacement for the old one. Where does it say that?TuxCoder said:So then this new chip is pin-compatible with whatever is being used by both E* and D* in all their existing receivers?!?![]()
I was referring to MikeD-C05's "change the chip out" discussion above. Changing it out won't work across the board (if on any receiver at all). But as bdemz states, an addon daugher card/module may help some receivers (but still definitely not that many models). I've heard of a select few receivers that have PCI slots or similar expansion interfaces--excluding smartcard sockets.mdonnelly said:I must have missed the part that says the new chip is a pin-for-pin replacement for the old one. Where does it say that?
I agree. Even if this new MPEG4 chip is pin-compatible, which I doubt, it wouldn't be cost effective for E* to disassemble each 811, un-solder this VLSI chip and put on a new one. I haven't opened up the 811 to look, but even if it has slots for add-on boards, there's a lead time for design, test and distribution that would be pretty close to the lead time for a whole new STB.bavaria72 said:Yup. Pretty much seals it for me. No new boxes till 3Q-05 for me.
RBBrittain said:Is it possible that an MPEG4-to-MPEG2 converter could be added to existing receivers? It would look like the existing DishPro legacy adapter (i.e., a box between the tuner and any LNBs/switches), but would be activated whenever a MPEG4 TP is selected; the converter would receive the MPEG4 signal, pick out the desired channel, and transmit it in MPEG2 to the receiver. It could communicate with the receiver via DiSEqC commands (DishPro receivers), extended legacy commands (legacy receivers), or by other connections (such as USB on 522 or 721, or Firewire on 921). Such a box may be cheap enough to let Charlie use MPEG4 as the solution to "two-dish".
I agree that an MPEG4 chip couldn't be added to existing receivers directly. Even a PCI card would be too complex for the average E* customer.
Yes, the decoding is only used only when presenting the picture to your Display device. Does limit its capabilities in a dual output box, such as a (not yet available) 942.gpflepsen said:Drawback: Only single channel HD decoding, or dual channel SD decoding. Does this preclude the chip from being used in a dual tuner HD box? Can dual chips be used in two-tuner HD boxes?
Lets see, I've got my chip puller handy. (these things are not soldered in) now can I figure out where the right chip to pull is, so i can put in my new BCM7411? Do I see a 27x27 336 pin chip somewhere?mdonnelly said:I agree. Even if this new MPEG4 chip is pin-compatible, which I doubt, it wouldn't be cost effective for E* to disassemble each 811, ...
Limited time offer
