can I just buy a joey off the internet and just replace the one I have without involving dish? will this work?
thx
thx
No, every receiver must be activated by Dish.can I just buy a joey off the internet and just replace the one I have without involving dish? will this work?
thx
That's correct.so then I assume since they have to activate it, they'll still charge the monthly fee even though I own it?
thx very muchthe fee is an outlet fee, not a lease fee, so it's the same fee whether leased from Dish or owned outright.
Exactly. This works great. Just be aware that you can only have one active stream from Dish Anywhere at any time so this somewhat limits your ability to replace receivers.If you have decent internet get an Amazon Firestick and use Dish Anywhere.
I thought Dish Anywhere was able to stay "internal" if your main receiver and the device that DA is on are on the same network ?If you have decent internet
true, but I have neighbors that don't have any internet (hard to imagine) so DA wouldn't even be an option, they'd need to have a Joey.I thought Dish Anywhere was able to stay "internal" if your main receiver and the device that DA is on are on the same network ?
I believe that you would need an internet connection to authenticate the device, but the actual streaming would be on your intranet.I thought Dish Anywhere was able to stay "internal" if your main receiver and the device that DA is on are on the same network ?
You can buy a Joey off the Internet and activate it yourself by calling Dish and giving them the receiver number. Yes you still get the $7 monthly fee but what you do not need is to have Dish tech come out to "install" a leased Joey. That is a $100 fee which is twice as much as the cost of a Joey on Amazon or Dish Depot.No, every receiver must be activated by Dish.
thx
WOW, is that a 30% tax on receiver leases?
I'd fight the"lease" tax. You pay the same even if owned. It's a programming access fee, not a lease fee.
Limited time offer
