Buzz S2010f Blind scan | SatelliteGuys.US
dish_in_the_sky
91
It looks like the blind scan (of the currentr satellite) will only lock onto signals if you have the correct satellite selected in the channel search menu.
This can be tedious if you don't know which bird you're on.
nah. I do a blind scan regardless of where I am. The issue with the Buzz is fast scan is junk...doesnt pick up anything
The detail works better. I scanned AMC5 one time with a C-band satellite selected (LO frequency was changed to be current) :)
? FTA and TimeTrax
Can you use a SW21 with linear and circular LNBs?
