C-band Back in the Day... | SatelliteGuys.US
stogie5150
Crazed Cajun Rebel
3,839
85
Slidell,LA
Here's two pics I found of our family's dish circa 1981-1985. 10 foot Fiberglass with a hand crank....wish I woulda taken pics of the back of the dish....:)
Check out the LNB assembly...they made it EASY to adjust! :up
much appreciated stogie. you just gave me the simplest solution to a problem i had with a project. to bad its to late to get into the shop. haha.
crackt out,.
I have the damndest ideas sometimes.....I still have the dish itself, in pieces, behind my Mom's house, the pole, and half of the mount. I think I might try and bring the beast back to life....stay tuned. :)
I dug it out of the woods this morning....no mount though, or LNB supports... BIG pictures...be aware dial-up guys...:)
I added the name tag pic....Satellite Earth Station Mamou LA, and a couple phone numbers....LONG disconnected I am sure...LOL
depends on what you are wanting to use it for. Ground mount it for a one satellite test dish and it looks like the brackets to hold the support arms are there ... point it at a sat with dvb-s2 and try it lets see if the old fiberglass dinosaur can draw in a signal.
And after much cleaning....looks much better. Still some staining but I don't think its anything some primer and paint won't cover...
Now...what color....Safety Yellow? :D
pickle green , anole green ??
I was thinking maybe some sort of stencil so you could cover the dish with green leaves.
That'll make it yard-friendly; it'll look like a tree from a distance. - :cool:
THEN, you use a different shade of green, and paint in a dozen or so anoles.
It'd be a Where's Waldo for all the neighborhood kids.
Attached is a sample (sent to me by a member here, who may care to claim it if he wishes! ) - :D
Well I can tell you what DOESN'T work. And that is spraying latex out of a regular spraygun. My dish looks like a gray orange. I used flowtrol, and thinned and thinned and thinned....just didn't paint well. I may roll it with some other paint to cover it and smooth it out... :)
EDIT: Added a couple pics....the one panel is the best of the four, the closeup is of the worst one....
I dunno,, give 'er a light sanding...
... and shoot another coat!
And remember, nobody ever sees these things up close anyway!
edit:
SKIN.!.?. That'd take one the size of a bedsheet!
Though, I'm not sure a King-sized would cover it!
I'm with the green one>nobody will notice from a distance, that first panel looks super, the 'bad' one, doubt it'll stand out very much from a few feet. I saw a VW bug one time that two drunk teenagers stole and painted with brushes, now THAT was a bad paint job, lol.
GI DSR-4000 ?
410 user question?
