C- Band dish alignment | SatelliteGuys.US
Adri
Australia
I have installed a C- band dish aligning to asiasat 3s (100.5E) , I can get about 80% signal level but I dont see any indication on the signal quality bar
anyone has some sugetions
If you are positive you have the elevation and azimuth properly set, you need to tune your receiver to a known active transponder. The signal strength is only an indicator that you have power to the lnb. If you have zero quality, either you are not set up properly with the mechanical alignment of the dish or you are not tuned to an active transponder. Is this a motorized or fixed setup? What receiver and lnb are you using? You are aiming at a satellite located at 100E. Are you within the footprint of this satellite?
Sent from my Timex Sinclair using SatelliteGuys
Asiasat5 105.5 degrees East not 100.5, Typo?
More information is needed, otherwise it's just guesses. Is this your first dish alignment? Your Latitude and Longitude? Polar mount (actuator equipped) or Az/El (single satellite) mount? A complete equipment list may also help.
Is the receiver programmed with an active transponder, receivable at your location, on the satellite you're aiming for? Without this, you'll not see a Quality reading. Asia Satellite Telecommunications Co. Ltd. Their footprint maps and channel list don't make it clear as to what transponders are in which footprint.
www.dishpointer.com will help in getting the aiming directions. Enter your Lat and Long, select satellite, click GO.
Looking for a channel editor with H264 setting
Dish & Lnbf combo
