C-Band Dish and receivers in Chicago priced low | SatelliteGuys.US
It just doesn't look like a 15/16 foot dish
Well they did not say that was the diameter! ;)
Looking at the photo and the way the dish is positioned... wide could mean from the feedhorn cover to the tail of the motor to some people! :D
'taint THAT big:
If the dish is in decent condition, it's certainly worth $35 for an 8 or 10 foot mesh.
If you can use the feed & LNB that's a plus, but I would probably get a GeoSatPro C2 for C-band only.
If the motor works, great. If not, well... replacements aren't so expensive.
I'd run it with a Gbox if not on a 4DTV receiver.
Make sure you get enough of the pole so you don't need to jump through hoops planting it! - :rolleyes:
C Band dish in Philly
922 Diagnostics H
