im looking for a dish blanket. something that covers the dish and dont stick to the blanket. i have seen them around on some headend dishes. if anyone knows where to buy them or has any ideas thanks
yes to keep the snow off. they are all mesh dishes. i had to brush off 9" and 1/2" ice this morning. would a heating system be better to use?What is the goal, to keep snow off the dish? Many dishes in our network have dish covers to keep snow off but they are very robust and heavy. A lightweight cover is going to get abused by the elements and whip around a lot.
those are the covers im looking for yes. i still thinking i may have problem with wild coming from back due to dish being mesh
i think if the cover used the arms to support it the snow would slide better?Most materials you would use will not block signals. However, talking from experience you are not likely to get anything to last long on the dish. Heating it is not practical, and when snow starts falling it will collapse any but the most robust covers. This is what our covers look like on a 4.5 meter dish, they probably weigh over 100 pounds. And our look angles are very low in Alaska, it will be worse where you are for snow weight, snow will not slide off like it does here they have to be taut like a drum.
10ft got 5 of them. im not a motor kinda person i would like to just try it and see how well it works. i get a lot of dry snow. we just got about 11" in the last 4 days. there was a little bit of ice say at most credit card thick. but i feel having the cover on there would get rid of that problem. i think its from the dish melting the snow away when it warms up and then gets cold again so it freezes on the dish again
i dont think the leaf blower will blow off stuck on snowUse leaf blower to blow the snow off.
Limited time offer
