Error 2 means the box is not receiving pulses from the actuator. Check the wire from the vbox to the dish for loose or broken connections (both at the vbox and at the actuator). Check the dish for binding and lubricate if necessary. If neither of these is the cause the actuator's reed switch or motor may have failed (reed switch can be replaced).Hi,
I am getting "Error2" from my V-Box6, and my dish does not move can anyone tell me how to troubleshoot
the V-Box6.
Thank you
This is exactly what is going on in your case. The vboxes have never had what it takes to properly move a large dish. They are better suited for small 6' lightweight primes or smaller. They work, but barely. I burnt out 2 of them.I've wondered (connections all checked) if the power supply goes weak and maybe stops the initial "oomph" needed to move the dish, thus it EXPECTS a pulse but the dish isn't moving.....and the error sees no movement. (just my theory.)
Limited time offer
