c band lnb arms | SatelliteGuys.US
c band lnb arms
perazzimx15l
SatelliteGuys Guru
134
Usa
i am wondering if the 6' WSI focal arms for the lnb have to be in a pictular place and if so wher do the arms need to be placed. can not get lock on first strike meter.
There are notch/grooves in the 2d row of screw holes from the edge where the arms fit.
Thanks Brentb636 i now have my setup like yours. Had a hard time telling the instructions that came with it because they are somewhat hard to read.
you are just about on your own with the wsi 6 foot special,but once getting it assembled and getting it on the pole without causing a lot of damage,you got a dam good 6 foot reflector.
My Solomend (sso) died yesterday.
Channel Master molded off set dish-odd shape?
