Well got my 10 foot dish tracking pretty good across the arc only have a question. I get 125w locked west of 127 double checked and that's what I get .has 125 or 127 moved ?
How do you KNOW it's "125w past 127w"? That doesn't even make sense. You KNOW your receiver does not KNOW what satellite you are pointed at, right?Well got my 10 foot dish tracking pretty good across the arc only have a question. I get 125w locked west of 127 double checked and that's what I get .has 125 or 127 moved ?
Using av8 sat finder I put in 4180 v 30000 125w and 4040 v 30000 for 127wHow do you KNOW it's "125w past 127w"? That doesn't even make sense. You KNOW your receiver does not KNOW what satellite you are pointed at, right?
IF you used the 127w satellite setting on your receiver to scan in 125w, and vice-versa well then, you'd think they were reversed.
Well, somethings wrong. Try these settings for 127w, and see what you get. There's supposed to be a couple FTA channels there. I can't see that sat myself due to trees, sorry:Using av8 sat finder I put in 4180 v 30000 125w and 4040 v 30000 for 127w
4080 V |
DVB-S QPSK |
29270-7/8 |
No signal on 4080 .on4040 I get positv sd ,HD smile sd HD 127wWell, somethings wrong. Try these settings for 127w, and see what you get. There's supposed to be a couple FTA channels there. I can't see that sat myself due to trees, sorry:
4080 V DVB-S
QPSK29270-7/8
On 125 I get 160 encrypted channels scanedNo signal on 4080 .on4040 I get positv sd ,HD smile sd HD 127w
4040 is 123w https://www.tvrosat.com/cgi-bin/cha...cryption=All&satellite_location=123:Galaxy 18No signal on 4080 .on4040 I get positv sd ,HD smile sd HD 127w
Seems like you're correct I'll have to triple check myself tomorrow , thanks it's not my first mistake lol
No worries. Mistakes are part of this whole thing. The only way to never make a mistake, is not even trying in the first place.Seems like you're correct I'll have to triple check myself tomorrow , thanks it's not my first mistake lol
Limited time offer
