GEOSATpro - C/Ku format on Micro HD | SatelliteGuys.US
GEOSATpro C/Ku format on Micro HD
Well it has to be some way. And of all the ways you could do it, this probably is better for single dish and fixed dish setups. For me I want the KU and C combined on each position. So it gives me something to do with the Ali Editor. I imagine no matter how the list is formatted, I would change it to suit my setup better.
I have done the same with the Manhattan but I must tell I Am a little gun shy since the last time I tried to make chances to the Micro.
Having a C/Ku Bud, it is one of the first thing that I do with my userdb file; I am using MES (MeidaBoxEditorStudio).
Helios
No. It is the .udf file. Save your current User Data Base, edit, save and load.
Go into the Channel Manager as save if you wish to use as the Factory Default.
GEOSATpro Subtitles via .srt files?
GEOSATpro MicroHD Channel List on OSD
