C32V37 Computer to DVI | SatelliteGuys.US
Not open for further replies.
cbmadcow
8
Hello world, I recently purchased a Zenith C32V37 HDTV television. Love this television except for the fact that it does not support 800x600 native res from a computer.
I recently downloaded the program powerstrip in order to manupulate different screen resolutions and refresh rates. I tried as many differnt sizes as i could, changing this and that and always endind up loosing the pic. I would get very close but some of the screen on the top and the sides would get cut off.
Is there anyone one out there who has figured out the exact screen resolution and refresh rate that would work on this television or maby a better program to use to try different screen sizes.
Any help would be greatly appreceiated.
Kevin B
Thats the same TV I have. I am feeding it will a Nvidia Gforce 5300 at 1113 x 626 with a refresh rate of 60 Hertz at 32 Bit.
Hope that helps. :D
thank you
omg thank you very much going to try that later tonight, how does it work do u use a program to get that resolution or is that one you can do with your video card!!!!!
Sony unveils world's smallest and lightest (HD) consumer camcorder
I got a new DLP tv and need some help
