Hi,
I have a few more questions before purchasing components to get this up and running...
What is the best cable to use?
What is the maximum length a cable can be/What is the optimum length?
[I will be running a Coolsat 5000 Platinum on a Winegard 76cm (31") Dish, motorized with a SG2100 Rotor]
And a newbie Question (probably all newbie questions
) How do you control the motorized dish? Is it controlled from within the Coolsat, or do you need some other type of controller?
Thanks again for the help in getting this set up.
