cabling the 625, basic | SatelliteGuys.US
sg9999
65
this is for a 625 and a dish plus twin LNB and 500 dish
For running a single tv setup only....
is it port 1 of LNB to the 625 with coax and thats it..???
dont need any dual tv setup stuff.
thanks
lnb 1 ?
does the coax go into the DP side with 1 port or the side with 2 ports....if, which one..
The side of the separator with two ports is the side that goes to the receiver's two tuner inputs. The other side goes to the coax leading to the dish antenna.
looking for a ppv guide on line....
Are you having Sling / DISH Remote Access Issues
