Caller ID dvr625 | SatelliteGuys.US
Caller ID dvr625
This is a known software issue with the 522/625 receivers. DISH says it should be fixed in a future software release, but is low priority due to the other issue which is where TV2 goes black and white or looses audio or both.
My 625 is the same. Go to system set up then diagnostics then hit connection. It will probably fail the first time. Do it one more time and you will be good to go.
I don't know what to do about my service..
Does E. Still use Legacy Lnbf for new install?
