Caller ID on 622 connected to DOCK N Talk | SatelliteGuys.US
dweber
1,833
2,648
Plain City, OH
I currently have my 622 receivers connected to my cable router and also connected to my Verizon phone line. I really like the caller ID through the satellite receiver since it allows me to see incoming calls. I often do not hear the phone ringing when I am watching a surround sound program. I am planning to eliminate my Verizon land line to save $75/month. Dock N Talk allows you to connect your cell phone to your phone jacks in your house. I read on the Dock N Talk we site that TIVO, fax machines, and satellite receivers can not use a digital cell phone connection to dial out due to the compression on a cell phone line. However, since my DISH receivers are connected via earthlink cable, they should be able to connect to DISH via the broad band connection. My question is whether, I would still be able to receive the caller ID through the DOCK N Talk? The web site for Dock N Talk https://www.phonelabs.com/index.asp says that caller ID will work on existing phones. Does anyone have any experience using Dock N Talk?
Another possibility is for me to use Vonage. This would cost an additional $20 per month. I used to have Sun Rocket which worked with my DISH 622 receivers. Thus, I'm pretty sure that Vonage would work. But if Dock N Talk would work, I could save the $20/month for Vonage.
That's not a bad idea. Unfortunately, I never tried it combining both of them. I will give it a try after going home. I have both dock 'N' talk and 722.
I got a GE Cell Fusion bluetooth to phone line adapter and it transmits the caller id number but not name, it works with the 622 but it doesn't work with all of my CID units. I don't think it puts out enough power.
Docnk'N'Talk has line out capability which can be used to connect to the internal line in the house. So, I think it outputs enough power.
Dock'N'talk works. When tested, it sends the caller ID information, but it does not transfer the name
I do not know how it handles when 722 tries to dial out.
Most cell phones and cell phone networks do not support Caller ID Name, which is the reason why these interfaces do not pass the name either. Nothing you can do will really change this.
Local HD Channels: OTA Versus DISH
Why No Ship Option with ViP612
