Camping with Direct TV | SatelliteGuys.US
viper_fte
4
georgia
I am new to this forum and a beginner in satellite knowledge. Currently I subscribe to a 4 receiver package for home use. Would like to know if i can just unplug my spare bedroom receiver and take it camping? Intend to buy a portable dish and tripod to use with the receiver.
If so, how? Is there anything special i need to do? Do I have to purchase a Direct TV dish or can it be a generic one?
thanks.. Viper_fte
most likely you wont get the locals you are camping if you are way beyond your home spotbeam.
u can if you got a tripod for the SL3 and the moisture doesnt screw up your reciever over night.
easier to just get a satgo
Quite expensive for the Sat Go though.
Viper,
If your camping it the same general area you will get your locals, most spot beams go around 50-100 miles, some more just depends, if you don't get your try throwing a pair of rabbit ears on the TV.
you can find deals on them. I picked one up that was 350 on fleabay. and satgos are owned equpment always...
Wow, thats pretty good .....
Is that the going rate for used units ?
How do you know if they work till you get it, I'd hate tyo buy one then find out it doesn't ..... with a dish, at least I can fine tune it myself and can visually SEE if it's damaged in any way. :)
Hey Stone,
Sorry, I was thinking of something different, I thought the SatGo was the Cube device that picks up the sat signal for you.
Jimbo
Problem with Locals on HR21-700
why are the "odds" notably lower than the "evens"
