Can 722K still get OTA after desub? | SatelliteGuys.US
peano
849
I know it needs a signal from the dish. And I know the guide data will not be there. But can a 722K or 722 still receive and record OTA after the subscription is ended?
no
once the receiver is disabled the DVR part doesnt work..the 942 **may** work for OTA since its older and record but dont quote me on that
Good to know. Thanks guys. I can get a 942 for $50. The DTV Pal is quite a bit more.
Yet, probably worth it. It will be supported in the future- there is no future support for 942s.
Youse pays youse money and youse takes youse chances.
Fooey. For $50 you can get an ATSC tuner card and record to your hearts's content. No DRM either. (I don't know this, but I suspect the DTVPal DVR doesn't make it easy to get at your recordings.)
Adding an additional HDTV Per Dish
Help hitting 129 Satellite
