Can a Dish500 be linked to a 1000.4? | SatelliteGuys.US
hillsmi
160
3
Michigan
Can an eastern arc 1000.4 be winged to a Dish500 with a DPP LNB? or vise versa?
Receiver is a ViP622.
Can the two dishes be ran seperately to a DP34, and then twin lines to the dual inputs of the 622?
Doable? How?
Doable? How?
Not in this instance, no switch is needed in this setup. You only need a line from the 500 dish going to the 1000.4 "lnb in" port. (Or vice-versa.) From there a single line from the dish to the receiver. Two if you don't have a DPP Separator. You only need a switch if you have more than 3 tuners. (You have more outputs if you plug the 500 into the 1000.4)
How many orbitals are you trying to get? 1 additional orbital can be routed to the lnb in on the 1000.4 lnb without the need for an additional switch
Vip 722 Audio/Video syncing problem w/ both live and DVR'd
No 129 signal.
