Can a DPP Twin be connected to a DPP44? | SatelliteGuys.US
miguelaqui
1,002
28
I am considering repointing my 105 SD to 121, using a DP Dual for 129, and a Twin on a D500...then , combining them with a DPP44; I no longer trust a DP34 DP-21 setup.
My question is.....will a DPP Twin go into a DPP44 and the switch will recognize the 2 sats; 119&110, just like a regular DP Twin?
I just wanted to get a DPP twin in case I ever wanted to downgrade and the cost of a DP Twin, DPP Twi, and DP dual are very close.
Yes a DPPTwin will just act as a regular DP Twin. I.E. you'll have to use both coax connections and the input connection will not be passed through to the DPP44
Equipment Question:
Locking dish network signal problem
