Can anyone help with this? | SatelliteGuys.US
jerzstyle00
67
dallas,tx
Looking to hook up sub VIP222k. Currently have following set-up on roof:
2 direct tv dishes with 3 legacy lnb's(110/119 and 118) going to 4x1 disqec switch.
1)is the VIP222 compatibile with both legacy lnb's and the 4x1 disecq switch?
2)If not compatible with disqec switch can it be replaced with a sw21 or a DP34?
3) If not compatible with lnb can legacy lnb be replaced with 119/118 LNB and be compatible with disqec switch?
4) Or will I need to switch out both disqc switch and legacy lnb with a 500+ dish instead using a DP33 or DP34?
Im looking for the most conservative way possible to make this work .Thanks
. . . will get better attention over in the Dish Network section of the forum . . .
Also, a topic that reflects the general area of the problem, might be useful, too. - :)
Diamond 9000HD flash dump
Azteca TV 93.1W HELP PLEASE!!!!
