Can D10 use P3 ? | SatelliteGuys.US
Can D10 use P3 ?
xrf1
54
Is there anybody know which access card can be used with D10 ?
Ebay has P3, P4, and P5. Can D10 work with all of them ? or only 1 of them ?
you cant legally buy an access card they are directv property and if you do ,,,,,,,,,,,you have to know it is a set up. stupid is as stupid does.....forrest gump
I means I plan buy a virgin card, then call DirecTV to activate it (and of course pay monthly fee). Is that wrong ?
The P5 is the only card that D* will currently activate. You may have problems getting the card activated if you don't go through D*. They only charge 20 bucks and they overnight it.
All D10's come with access cards. If you don't activate the access card that came with the D10 the dealer you purchased it from will get a $130. charge-back.
-Robert
DC Locals
Multiswitch question
