Can Digiware7000 control Sg2100? | SatelliteGuys.US
t_n
53
Minnesota
Hey guys,
Friend just saw my dish can move :D , now he wants to make his dish move too. Can this reciever control the Sg2100?
Thanks for any info.
yes it can
in the antenna setup, second line says "fixed"...change it to Diseqc 1.2 and that will allow him to move the dish
Setup is kind of goofy
-go into antenna setup and where it says "fixed" change to Diseqc 1.2
-exit out (save first) and go into channel scan. This is where you can move the dish
I mentioned this in the review I did (I have a KUSat 2600 which is just like a 7000)
if you press a direction to nudge it and press it again real quick, it starts motoring like you are holding down the button.
Press the direction to nudge it, wait at least a second then press it again. It should work better
Only need 1 channel
Agila 2
