can hr24 run two tvs like dishs 722? | SatelliteGuys.US
OSD771
256
Pokey
So I'm pretty sure the answer to this is no, I install dtv and dish and have never heard of anyone doing it.
But is there a way to run two tvs off one hr24 without mirroring or slaving? I want to actually use the second tuner seperately. I know its prob not possible
Not on two different channels, but if you just want to use one receiver for two tv's that you don't watch at the same time then yes you can. Use HDMI on one and component on the other as long as they are fairly close to each other.
Yeah I figured it was impossible. It would take different software and then possibly a diplexer or triplexer like dish. Also seperate remotes that are dedicated to a tuner.
Just thought I would ask! :)
"Your receiver is activated for whole home dvr."
Wanting to get whole home DVR, current subscriber...
