Can I catch Amazonas 61.0W?? | SatelliteGuys.US
slimmswitch
118
I was wondering if anyone can just make sure if it is possible for me to catch Amazonas 61.0W ( channel i want is 4137 H tp 19 TV Cidade (Fortaleza) ) Currently I catch intelsat 805 at 55.5 so i think it's fine and from the footprint i think i'm good.
here's the foot print link
http://www.hispamar.com.br/site_eng/satellites/img/cobertura/cobertura_amazonas1.html
I have a 7.5ft dish with Cband lnbf, and i'm located in toronto ,ON.
Please advise
thanks
slimmswitch,
i am located near kansas city missouri and have picked up amazonas 61.0w in digital format ku side, with a p* dish and a .5 lnb hooked up to my fortec star ultra. with no trouble. of course amazonas has a north america feed, so the channel in question will depend on which beam it is located on, NA or SA. good luck
Transponders/Symbol Rates
I had Amazonas booming pretty well under Echo 3 by accident with, linear settings, KU system.
Saw what had happened dumped it all back to original Echo 3 settings and tried to set up a new satellite, but no luck.
Any info there from KC Missouri?
Hey TIDI have you gotten the catch to program in that bird yet??
tdti1 said:
You should have no problem getting that feed, I have not programmed that bird in yet, but will tomorrow.
5 digital SR
Dish Motor Question
