Can I get all HD this cheap in Direct Pkg? | SatelliteGuys.US
trido
440
17
Southern indiana
Thinking about trying Direct out leaving Dish.
I still have cable and only realy want is HD
Online it appears I can get HD for 39.95 a month for first 3 months then another 4.99 more for HD after three months
I cant continue with Dish this cheap
Also I told my local installer I only want ONE dish he said if I dont want local SD channels I can use just the 7 lnb dish does that sound right?
Here I know for locals we must have that second dish( dont need it get locals via cable and Qam tuner)
Does the below look right Direct will let you add HD pkg to their low end Family pkg? Free HD receiver
Your First Month's Bill FAMILY $29.99
DIRECTV® HD EXTRA PACK $0.00 after 3 months i pay only 4.99
HD Access $9.99
First Month's Total: $39.98
OOPS I found a problem example with only the Family PKG it doesnt have CNN so even though I pay 9.99 then the 4.99 for HD I would not get CNN HD is that right I have to have the channel in my basic pkg if it has SD then I can have it in HD?
Thanks again for any help clearing this
thanks
HD Access $9.99
thanks
At this time, that is correct. You will get the HD versions of the channels that you get in SD. Also, there will be a HD pack that includes the HD channels that don't have a SD counterpart (like HDNet) that will eventually cost extra.
Ok so I am sure before I call in this case with me only having Family Pkg at 29.99 I can NOT get like CNN HD because i do not get their SD of CNN?
Is this correct if so then Family Pkg isnt the way to go to get all HD programming.
I had hoped thier two fees of 9.99 plus the 4.99 got all HD except HBO prem channels.
You are correct. You won't get the HD channel if your package does not have the SD version.
What Cables are supplied ?
0 for 2
