Can I receive Atlantic bird3 in montreal? | SatelliteGuys.US
antenna
18
Hello Could somebody please tell me if it's possible to receive Atlantic bird 3 Ku band in Montreal Canada and if so could I be able to receive it with a 39 inches dish... Thanks for the answer...
The piece of land on the upper left hand corner on the footprint map is NOT Canada. It's Greenland.
Had the footprint included Canada, I would have moved to the Maritimes after retirement...
atlantic bird 3 in the US
hello every body,
to follow on the subject of atlantic bird 3, i have this question:
Is anybody able to receive the US beam in Ku from AB3 centered on Boston area (EIRP 45 dBW) and what specific channel are you viewing? is tf1, france 2, france 3 receivable? what receiver is required?
thanks to share your experience.
lemonde
negative...the beam is only over Europe
On Lyngsat, it says the beam is "superbeam" which is only Europe
has anybody tried AB3
thanks iceberg.
Let me clarify that i just want to double check if anybody has tried viewing something in Ku band on AB3, not just read lyngsat data.
If so thanks to share.
lemonde
Dish Size Question??
Will this setup work?
