Can I Split one line from superdish using dp34 | SatelliteGuys.US
johnisback
3
Hi,
I upgraded to superdish and currently I have two 301 receivers in two rooms. I have the top 60 package and an International package (Greek). I want to add one more receiver in another room. First I tried to split the cable goint to the one receiver using a simple splitter. I was able to see the channels for the 60 package but when I tried the greek channels then the reception was freezing. Is there any way that I can do this by using the existing lines and maybe a dp34? and how? Or do I need to run a seperate line from the superdish. Any help will be appreciated! Thanks
You would have to run a seperate line from the DP34 in order to feed another receiver.
If you run out of outputs on the DP34 on the bottom you can go to the 3 passthrough outputs on the right side of the dish and whatever satellite is on the left side of the switch will have that satellite outputting on the right side of that switch.
Bought a new 522 on Ebay Lease fee?
CableVision Layout For Voom??
