Can I use Diplexer? Also, need CT help.. | SatelliteGuys.US
dschribs
20
Currently I have 2 dishes on my house (Standard and HD). I want to add the Winegard Sensar Batwing to try and pick up HD locals. Can I still use a Diplexed set up with 2 dishes? I want to avoid running another wire if at all possible...
Also, anyone know of anyone in the central CT area that could install this antenna for me for a reasonable price? Dish won't touch it...
If your stations are nearby and strong, diplexing can work, but best case is run two lines.
Are you sure you want to use a batwing?
There are much better alternatives out there.
That is why they won't touch them ya know.
I'm in a similar situation. I'm running a diplexer but want to know if I can add a pre-amp like the Channel Master 7778. If I do, do I connect to the actual OTA feed (prior to the first diplexer) or prior to the TV, as designed (after the second diplexer). Currently I have a Channel Master 3679 antenna on about a 25' mast and I live approx. 50 miles from the area tower farm.
Thanks for the input.
I would run a new cable from 3679 to your rec. (no diplexers) without the diplexers you may not need the amp. If you still need the amp no problem.
Diplexers reduce signal.
Minneapolis PBS moves channels around
Cm3671 & Cm7777
