We are going to travel and thought about taking the Hopper with us so we could watch a movie from theh DVR at night.
Will it work without a sat signal for a week?
Thanks very much
I just tried booting my H3 with no satellite connection and was able to get to the DVR fine. Once the "acquiring signal" dialog comes up, just hit the DVR button.Nope, won't start up if it can't find a signal. Why don't you just use Dish Anywhere either your iPad, aPad or laptop. You can access anything on the Hopper using that plus stream live TV (doesn't have to be on the Hopper) if your hotel room doesn't have that channel but you are subscribed to it.
That's not trueNope, won't start up if it can't find a signal.
Thanks for the replies.
Hard as it may be to believe I don't have a "smart phone" ......
I decided I should get off my arse and just test the thing which was easier than I thought it would be.
How do I phone home and what does that mean. It is not connected to a phone line ... just the InternetNot sure anyone can say how long it will work without "phoning home" and stopping. I've heard one week, one month, etc...
Sent from my HTC6535LVW using Tapatalk
Leave it plugged in and test it from time to time, maybe each day, and then tell us when those recordings stop working, and they will...I have a Hopper 2K that has been in the closet since March 2013. I just plugged it in and I can still watch all the recordings and even the Rentals that were on it. I can't access Prime Time folder though as it says no guide data.
Limited time offer
