Can lnb freq be changed? | SatelliteGuys.US
Grampa
21
Some of the satellites give a stronger signal if I change the frequency of the lnb to 5.150. Is this what Im supposed to do? Or do I set them all at 10.75?thank you. Grampa
C-Band is 5150
KU Band is 10750
that is the LNB LO frequency...you don't change that
Some transponders are stronger than others and thats the nature of the beast :)
Kusat 2600a Pro what digiwave model is it?
Channel Master 75E LNB Holder
