can someone check 91W Ku? | SatelliteGuys.US
Jim S.
When someone asks you if you're a god, you say yes
5,799
1,546
FN11od
I'm getting 4 feeds at week to moderate quality, but nothing on any of the fixed channels, useless though they may be. No "occasional use", no TXCN, no training network channels. I'm worried that the wind might've moved my dish, although it was fine earlier when the wind was worse than it is right now.
same here
none of those "occasional use ones" get a signal
The data TP's are still maxing the meter so just that TP is off the air
right now I get 4 feeds (520 CST) but thats it
all at pretty good signal (around 75-58 on the CS5000)
Thanks! It's the coldest day of the season so far, I wasn't looking forward to re-peaking the dish. The feeds are weaker for me, but I'm using an LNB off the side of my 97W dish, so it may be normal.
sounds like it
I did PM you what I was picking up and what the CS5000 showed for quality. This is on a 36" dish...and its cold here too in MN (balmy 8 above)
Homemade Conical Scalar Ring
River Broadcsting new on Galaxy 19 (97W)
