And my question is why isn't there a VLC media player plugin to handle it.
That's really odd, because when Nasa UHD was on 101W, the Mio decoded it just fine, and it worked great!
I don't know, as the sat it's on now is blocked to me.Is it using a different kind of modulation now?
Here's a snap I took back then, from 101w:
Difficult to understand. Just a why thing I guess. If you can't watch these channels on the box but you can send them out over Ethernet and even a crappy pc with the right software and codecs can. I'm guessing one way the video/audio gets piped out over HDMI to the TV. And if the Broadcom chipset can't do 10 bit or 4:2:2 through HDMI.If the hardware chipset can't handle it, then a VLC plugin couldn't handle it either, correct? In this case, I wouldn't think software could overcome a hardware limitation, in the same way a plug-in couldn't enable the Mio to output 4:2:2 video (natively). I think.
When you decode NASA UHD on your PC, it's doing the work, you're simply "hosing out" the feed from the Mio
Yup.Can the Mio playback current NASA UHD recording via VLC? I won't have time to look at this myself until the weekend.
VLC on Mio
May have to try that on my chromecast dongle as it has kodi app available.I am in the same situation. My dreambox played Nasa UHD just fine up until about two months ago when they switched to 10bit. The specs for the dreambox 920 say it supports 10bit. So, who knows. Being these things are decoded by the VPU within the chip, I have never seen anyone (in satellite STB's) attempt to stop gap other codecs via software decoding. - I have only seen this on PC's where the CPU can sometimes be strong enough to be able to software decode these complex codecs.
I decided not to stress over this, because it appears 4K is all but dead on Satellite these days. Came and went quick because of IP streaming. I found a good work a round. I have a cheap china made KODI box that cost me about 35.00 shipped. It handles the HEVC 10bit codecs (NASA 4K) stream flawlessly. I added a M3U file on my KODI that initiates a stream of the NASA 4K channel. So, i just tune to NASA, and then click the NASA M3U link on my KODI and my dreambox streams it to the KODI and it plays on my TV without incident.
I will also tell you that when they install KODI/VLC within the satellite receivers, they typically do NOT add any additional codecs, so you are still limited to the codecs that the hardware within the STB support, so adding KODI/VLC software to the receiver does not usually solve that problem. I have attempted this scenario in two situations, and both times, the VLC or KODI installed on the satellite receiver did not allow me to watch anything additional. - Why? They utilize the same hardware VPU and thus have the exact same limitations you are trying to subvert.
Is it possible to install an additional codec or decoder to allow software playback of recording?I will also tell you that when they install KODI/VLC within the satellite receivers, they typically do NOT add any additional codecs, so you are still limited to the codecs that the hardware within the STB support, so adding KODI/VLC software to the receiver does not usually solve that problem. I have attempted this scenario in two situations, and both times, the VLC or KODI installed on the satellite receiver did not allow me to watch anything additional. - Why? They utilize the same hardware VPU and thus have the exact same limitations you are trying to subvert.
Limited time offer
