can this be done?? | SatelliteGuys.US
can this be done??
theslag
229
Im thinking of getting a second TIVO receiver for my bedroom but only have one line to that room. I have a new oval dish with the multi switch built in. Is there any way i can split the signal in my bedroom so I can use the dual tuner? My friend thinks I cant, but hey, you never know..
Thanks!!
You could, but it would be costly. You would need 2 lines from the dish hooked to a stacker, then a de-stacker at the receiver end with 2 short runs of coax cable to your DirecTivo.
Triple LNB to 2X4 Multiswitch works?
MLB games on regional sports package
