can u hook 2 (or more) separators in series?? | SatelliteGuys.US
redeye
15
assuming you have a DP+ signal coming in on a single coax, and you install a separator to put the signal on 2 coax'es (like to run a dual tuner receiver), can you put another separator on one of those 2 lines to end up with 3 input lines?? and if 2 work, is there a limit to how many times you can separate the signal?? thanks for the help....John
you can have only one separator because only port one is DC pass. not second and it will over power everything
use a dishplayer ir keyboard with a 522,501?
Problem with 311 receiver
