Can you use VIP 922 for HD set, SD set and PC/iPhone? | SatelliteGuys.US
satellitecustomer242
13
Wake Forest, NC
I am considering upgrading from the VIP 722 to the VIP 922 so I can get all the "SlingLoaded" features as shown in this brochure that is on Dish Network's website now:
http://www.dishnetwork.com/downloads/product_brochures/922_Brochure.pdf
It says this in THIS brochure:
"Connect ONE high-definition (HD) TV for viewing at home,
plus enjoy TV Everywhere: "live and recorded programming on your computer or mobile device".
I saw this other VIP 922 posting from SatelliteGuys last year:
http://www.satelliteguys.us/dish-network-forum/196739-new-dish-922-spec-sheet.html
Here's the brochure from this SatelliteGuys webpage:
http://www.satelliteguys.us/attachment.php?attachmentid=45370&d=1260839967
In THIS brochure, it says:
"TWO independent TVs supported
--TV1: HDTV or SDTV outputs
--TV2: SDTV outputs"
"Independent Output to 2 TVs In Duo Mode"
"SlingLoaded™ Yes"
Basically, what I want to know is ... does the new VIP 922 support a hookup where you can independently watch a particular channel on HDTV with TV1, AND you can independently watch another channel on a standard definition TV (SDTV) in another room, AND you can also view a "live and recorded programming from your computer or mobile device" (TV Everywhere)?
Did Dish Network get rid of the feature where you can watch a separate channel on a standard definition TV in another room so that you can have this new SlingLoaded feature where you can watch on your computer or iPhone?
Does there need to be THREE independent tuners in order to watch one channel on the HDTV (TV1), a different channel on the SDTV (TV2), a different channel on the computer/laptop (TV3)?
By using the Zoom in my browser, I noticed that there is a "Remote Antenna" and a "Home Distribution" screw-in on the back of the VIP 922. What is it there for if you can't use the remote antenna in order to change the TV2 channel for a standard definition TV in another room?
Bottom line, I just want to have all the same features you can get with the VIP 722 PLUS all the latest "SlingLoaded" features. I want to be able to watch a separate channel on the HDTV, a separate channel on the SDTV in another room, AND a separate channel on the computer/iPhone. Does the VIP 922 do this? I need to know whether I even want to get the 922 at all of if I should just wait for an even newer one.
I'm looking to get an answer to the same thing. Bascially can 3 seperate "live" Tv channels be watched simaltenously?
One through TV 1 (HD), the second through, TV 2 (SD), and the third through the Sling Option on my Laptop. Or does the Sling Option mean one of the TV 1 and/or TV 2 users have to be watching the same channel as the Sling user.
TV1 is your HD output. TV2 is your Sling Output. Dual Mode was disabled in software shortly before release. You still have two satellite turners though, so you can watch live TV over TV1 and Sling live TV as well. When a recording needs to start though, one of those tuners will be taken over by that.
There is only support for one TV.
Don't read too much into the advertising as the ViP922 appears to be far from completed.
If you want Sling support, buy a Slingbox. Let someone else alpha test the ViP922.
Inexpensive option to add second HD reciever
When can we get these Sling Extenders for our VIP 922 boxes?
