Canada / Northern USA Signal Report Needed: SatMex6 KU | SatelliteGuys.US
SatelliteAV
6,486
186
Roseville, CA
A new transponder is testing on SatMex6 KU for our broadcasting partners, Hope Channel / Esperanza TV. They are wishing to determine the footprint of this new transponder and how well it can be received in Northern USA and how far into Canada.
Please assist with a reply including your approximate location, dish size, time, weather conditions and Signal Quality comparison for these 4 frequencies:
11990 H 10799 SL: SQ:
11995 V 4818 SL: SQ: *NEW
12080 H 25635 SL: SQ:
12089 V 3617 SL: SQ:
Example:
Sacramento, California
90cm Dish
10:45pm Clear, 75 degrees
11990 H 10799 SL: 75 SQ: 79
11995 V 4818 SL: 75 SQ: 72
12080 H 25635 SL: 80 SQ: 82
12089 V 3617 SL: 75 SQ: 66
Thank you everyone for your continuing support and assistance.
Have a great weekend!
Omaha, Nebraska (NW ~40mi)
1.2 M Dish
0500 am CDT 10/16/2010. Clear and totally calm, 53 degrees F
Readings taken with an AZBox Premium Plus STB
11990 H 10799 SL: 63 SQ: 81
11995 V 4818 SL: 63 SQ: 76
12080 H 25635 SL: 65 SQ: 87
12089 V 3617 SL: 62 SQ: 61
Rison, Ar. 71665
Primestar 84E (30X40) with matching Hughes Ku Feedhorn, SG2100 , Coolsat 5000
54 degrees F , Clear , 7 am CDT
11990 H 10799 SL 82% SQ 91%
11993 V 4818 SL 77% SQ 90%
12080 H 25635 SL 89% SQ 94%
12089 V 3617 SL 79% SQ 87%
Rison, Ar. 71665
Primestar 84E (30X40) with matching Hughes Ku Feedhorn, SG2100 , Diamond 9000
54 degrees F , Clear , 7:10 am CDT
11990 H 10799 SL 76% SQ 77%
11993 V 4818 SL 71% SQ 74% * 11995 V 4818 wouldn't read *
12080 H 25635 SL 79% SQ 81%
12089 V 3617 SL 72% SQ 66%
London Ontario
Mostly clear skies with small amounts of scattered cloud
1 Metre Dish with Sadoun brand Universal Ku LNB
My Fortec Classic NA doesn't separate Signal Quality and Signal Level, so I'm simply listing the quality I've received.
11990 H 10799 SQ:46%
11995 V 4818 SQ: 46%
12080 H 25635 SQ: 59%
12089 V 3617 SQ: 19%
These low numbers are starting to make me wonder if my dish needs fine tuning. These are some of my 97 west qualities to help you make a comparison.
12115 v 22425 SQ:46% (Access America / Pastor Scott)
12177 v 23000 SQ:53%-60% bouncing
Looks like I need to fine tune the Ku dish. If you decide to use these numbers, take into consideration that this dish appears to be less than perfectly tuned.
I'm pretty far north...
Saskatoon, Saskatchewan, Canada...
36x39" dish dmx522 lnbf, coolsat6000. 8pm eastern, weather is partly cloudy and around 10 degrees C...
11990 H 10799 SL: 87 SQ: 68
11995 V 4818 SL: 84 SQ: 70
12080 H 25635 SL: 92 SQ: 87
12089 V 3617 SL: 85 SQ: 87
hope this helps... :up
I'll post tomorrow...dish is right now at a different sat for the Boise State game then the Hawaii game ;)
Victoria , BC
1.2m Dish
18:00 Cloudy, 13 C
Azbox elite
11990 H 10799 SL: 79 SQ: 47
11995 V 4818 SL: 78 SQ: 56
12080 H 25635 SL: 84 SQ: 62
12089 V 3617 SL: 78 SQ: 60
Brockton, Massachusetts
1.2m Dish motorized
10:00pm Mostly Clear, 46°F degrees
Humidity:66% Wind Speed: NW 10.4 MPH (9 KT)
AZBOX ELITE COOLSAT 5000
11990 H 10799 SL: 84 SQ: 45......................SL:78 SQ: 69
11995 V 4818 SL: 70 SQ: 49......................SL:74 SQ: 72
12080 H 25635 SL: 84 SQ: 61......................SL:88 SQ: 74
12089 V 3617 SL: 68 SQ: 58......................SL:76 SQ: 75
From 97W 49N
Clear, 32F, breezy, 0740Z (0240 central time)
10' dish (see signature below)
11990H10799 Q = 63%
11995V4818 Q = 54%
12080H25635 Q = 67%
12089V3617 Q = 55%
Unable to get readable signals from 33" dish.
Glad to help out any time!
-C.
London,Ontario CANADA
100cm Dish
10:17am Cloudy, 48 degrees
11990 H 10799 SL: 65 SQ: 46
11995 V 4818 SL: 64 SQ: 48
12080 H 25635 SL: 65 SQ: 58
12089 V 3617 SL: 63 SQ: 50
Toronto, Ontario, Canada
85 cm by 93.5 cm dish
11:30 am, high cloud, 13 degrees
11990 H 10799 SL: 45 SQ: 23
11995 V 4818 SL: 42 SQ: 29
12080 H 25635 SL: 60 SQ: 36
12089 V 3617 SL: 48 SQ: 24
Minneapolis, MN
30" Winegard dish, Coolsat 5000
11990-70
11995-72
12080-75
12089-66
63 is threshold on CS5000
45.4 N, 122.6W
Coolsat 6000 0.06 FW
Geosatpro 90cm
JSC321 (Grey Tracker II clone)
SG2100 H-H motor
Code:
11990 H 10799  SL: 80    SQ: 72
11995 V 4818   SL: 76    SQ: 69
12080 H 25635  SL: 87    SQ: 75
12089 V 3617   SL: 76    SQ: 69
:up Thank you for the replies. Surprised that the SatMex 6 signals are this good up North! :D
The broadcaster is very thankful for your information as they are exploring the offering of unique programming on this satellite.
Good Deal on Compression Tool!
Pansat 2700, help please
