Cancelled Dish. LNB return question | SatelliteGuys.US
termite
34
I called dish last week and cancelled my service and they sent me a box
yesterday to return my leased receiver. Inside the box I see a flyer which
says I'm required to return the LNB as part of the return process and goes on
describing how to pack it along with the receiver.
My dishes are way up on the roof (installed by dish) and do they really expect me
to return these LNBs ?? When I cancelled, CSR asked me if my dishes are
accessible and I said no. Then he said I don't have to worry about those.
However,now I'm worried if they charge me if I don't send these back.
Appreciate your input/experience on this.
There have been numerous posts regarding situations such as yours. If you told 'em your dish was not easily accessible (on the roof) and they told you not to worry about it then don't. You'll be fine.
Ed
Thanks guys ! So I'll assume the LNB return instructions in the
box are just something they send to everyone and I can safely ignore.
Thx !
Tuner 2 reception error
Stupid Timers!
