So here is where I'm at.
My service was already setup for 1 ViP622 and 2 antenna's (110/100 & 61.5). The new cards have been installed in the receiver for a fe months already. My Dish500 antenna went bad leaving me with only the 61.5 dish working. Service was very flaky at best as 110 and 119 were gone. 50% of the time I was looking at the SEARCHING FOR SATELLITE screen. I had wanted to go to a 1000.4 dish and this issue finally pushed me over.
I assembled my 1000.4 dish. I removed the dish for 61.5 from the mast and put the 1000.4 dish on the mast. Using a compass, I pointed to dish to 186º with the elevation and skew set. As per the instructions I connected my meter to 72.7 (port 2). and fine tuned to the highest reading I could get. I connected the receiver to the antenna.
I go inside and turn on the receiver and TV. Go to POINT DISH screen and I have the following issues.
1. My only options for DISH is SUPER DISH, 300 or 500. I cannot select 1000.
2. I cannot select 72.7. I can pick from 61.5, 72, 77 105, 110, 118, 119.
3. I picked 72 as it was the closest and DISH = 500 .
3. I cannot see a signal at all. Nada, Zilch, nothing
Any help before I spend money getting a local tech to come out?
I called DN Tech Support and they verified the pointing angles with me. I am in an RV so DN will not get involved with sending a tech out.
