Can't access 2nd F connector on LNB w/T90 | SatelliteGuys.US
cracklincrotch
1,026
Halifax, Nova Scotia
On my T90 I've got an LNB right over top of the two arms that hold the secondary reflector. On each of them I can only access one F connector, limiting me to only one receiver on those particular sats.
Anybody know of a right angle adapter I could get to hook a cable up to the second F connector of a LNB?
Radio shack sells right angled adapters (gold ones linked...I know they make chrome ones that are cheaper
part
What LNB's are you using? I know the Sadoun ones leave very little room for error
I'm using standard linear LNBs made by Samsonic. Got them with my T90 from Wavefrontier.
No Radio Shack up here in Canada anymore. Circuit City bought them. Anywho, one of the local stores has three. I'm going to be buying them out. :)
If the right angle connector still does not fit, you can always try turning the LNBF upside down. Might need to make a modification for water drainage and seal those connectors..
DUNA TV no longer free on 97W
Free Shipping?
