Can't acquire siginal | SatelliteGuys.US
BruceE
80
We had a storm pass through & now my receiver can't acquire a siginal. I have a VIP622 DVR receiver. I can get the screen that says acquiring siginalbut the bar does not come on or move. Can anyone help with this problem. I have done a disconnect with the power 3 times with the same message everytime.
Thank you,
BruceE
Thank you,
BruceE
You can try running a check switch test. If you get an error about fewer satellites than before you will want to cancel that message. If this doesn't correct it, PM your account information and I can set up for a tech.
Zach, After running switch test it show no siginal at all, but I have 2 other tvs that have a siginal. Any idea what my problem might be? How much is a service call?
Thank you,
BruceE
Did it say that satellites were missing?
Which sats by the way? 61.5/72.7/77 or 110/119/129?
Thank you,
BruceE
If you don't have it add the protection plan service call will be $17 I believe. If you have 2 receivers still working either the cable was damaged or the receiver. PM Zack to set up the service call.
Simple request to reaim my dish - BIG PROBLEM
remote to remote programing questions
